m42 dyno data`
  • jakeb
    • 1909
    m42 dyno data`
    I finally have my dyno up and going and starting to get some good data out of it. Still dialing things in but I think the numbers below are close....
    I will be dynoing a turbo m42 (one of my kits) next week. Looking forward to what it shows above the numbers below.
    Will be logging
    hp/tq
    rpm
    mph
    boost
    afr (better than the numbers below) coming right off the mtx-l output
    maybe afm and maf 0-5v outputs
    My m42 powered 2002 on it.
    and some DATA
    This is two graphs of the same car when the engine was just warming up and then fully warmed up.
    Stock chip vs a "tuned" chip
    stock report
    tuned chip report
    and just the tuned chip graph
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • Balleristic31
    • Aug 2009
    • 4198
    Great baseline data jake! Looking forward to the turbo #s
    -NICK
    • jakeb
      • 1909
      Posted in the m42 turbo kit thread too
      Did some pulls today...boost was a little higher than it should be so numbers are a little higher. BUT things are looking very good.
      Boost is a little high on this one so it is a little leaner than I would like. Need to adjust the preload on the wastegate and/or richen the tune up a bit.
      Same dyno and specs as this graph from a stock NA m42 with TMS chip
      [img]https://lh3.googleusercontent.com/-vdijkSxVyUU/VWe4VUgnUlI/AAAAAAAAWxE/lrM-7flf7G8/s800/m42%252520tuner%252520graph.PNG/img]
      • Vanilla Gorilla
        • Dec 2006
        • 357
        Damn dude! Some solid numbers!
        • roguetoaster
          Biggus Tippus
          • 7830
          Oh my!
          Outside of the turbo components is that car running any other modifications like a light flywheel?
          • gearheadE30
            • Jun 2007
            • 3734
            hmm, makes me want to take my turbo M42 to a dyno...
            Project M42 Turbo
            • Uber E30
              • 1409
              gaaah, thats like a 1hp per 10lbs ratio, which is about the equivalent of an e46 m3. What PSI is that at?
              -Alex
              • Dj Buttchug
                • Jun 2010
                • 7688
                nice
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3430
                  I'm impressed.
                  Same.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • ccsdo5
                    • Mar 2013
                    • 708
                    looks good Jake! I might be heading out to Michigan sometime in the near future to look at a car with my friend, I'll send you an e-mail I'd love to stop by the shop and see what you're working on if you have the time.
                    Varg, I want to guess your car is somewhere in the 250+ whp area..
                    -Dee
                    5-lugged turbo 318is Barn car
                    IG: @deebelmont
